New Fixture Definitions
ausmichael
I have a bunch of new fixture definitions that I've made but not shared yet
XMLite Mini Hot Beam
Hong-Yi G100
Laserworld EL-900RGB
SHEHDS Waterproof LED Par 7x18W
Chauvet Colordash PAR Quad 18 (I copied this off the PAR 7 I believe but with lumens, dimensions, etc. updated to match the bigger 18-LED unit)
Yuer IP65 Pixel Blinder
Yuer Stitching Retro Light
Laserworld-EL-900RGB.qxf
(5.36 KiB) Downloaded 87 times
HongYi-HY-G100.qxf
(6.54 KiB) Downloaded 83 times
Chauvet-Colordash-Par-Quad-18.qxf
(4.29 KiB) Downloaded 86 times
ausmichael
Maximum attatchments is 3, here's the second batch of fixtures
Yuer-IP65-Pixel-Blinder.qxf
(5.72 KiB) Downloaded 71 times
XMLite-Mini-Hot-Beam.qxf
(14.08 KiB) Downloaded 82 times
Shehds-Waterproof-LED-Par-7x18W-RGBWA+UV.qxf
(2.38 KiB) Downloaded 87 times
ausmichael
And here is the last fixture
Yuer-Stitching-Retro-Light.qxf
(11.81 KiB) Downloaded 78 times
ausmichael
Here is an updated fixture definition for the XMlite Mini Hot Beam
I have added Gobos (or at least the closest gobos I can find in the QLC+ directory) and Colour presets
XMLite-Mini-Hot-Beam v2.qxf
(19.29 KiB) Downloaded 45 times
Yestalgia
Thanks for the hard work, I know finding gobo images is a pain!
ausmichael
Here is an updated fixture profile for the HongYi G100 including gobo and colour macros, strobe rate, and updated beam angle
HongYi-HY-G100.qxf
(8.86 KiB) Downloaded 37 times
Added, thanks
