Off button for RGB Scenes and Matrix's
IncursusSenior
Real Name: Socrates Fuertes
Hi Folks.
I'm very new to QLC+ so pardon my ignorance. I have a simple 12 LED Par scene controlled by MIDI using Reaper set up in a Virtual Console. It goes from Red to Blue as it follows the MIDI Que's. My issue is the LED's stay on Blue after the MIDI triggers are complete. How do I set up an off switch/button targeting specific fixtures? I have tried creating a button in the Virtual Console and attaching a function with all the sliders of the fixture in the off position but it doesn't seem to work correctly. I can turn on fixtures using MIDI with no problem, but I can't seem to turn them off. What section of the QLC+ documentation talks about sending off commands? Thanks for the help.
Happy Holidays!
MichelSliepenbeek
Real Name: Michel Sliepenbeek
You can use a Solo frame (https://docs.qlcplus.org/v4/virtual-console/solo-frame).
If you put your "all sliders in the off position" button in a solo frame with the other buttons, the solo frame will turn your other scenes off.
You could watch this video: https://www.youtube.com/watch?v=NZ-zHbWgDQQ
