Hello Guys!
I am a lighting technology beginner. I bought a Eurolight interface and installed QLC+. After a few tutorials I still can't find the reason why my interface is not listed in the inputs/outputs tab. Can anyone help me with this? The driver for the interface is installed. I was able to test it with another software (DMX Controll 3).
I've attached a screenshot showing my input/output tab. The interface is plugged into COM3.
Please Help. I really wat to try or use qlc+. Im hyped.
Eurolite-DMX512-PRO Interface not shown in Inputs/Outputs
If you check this page
https://www.qlcplus.org/discover/compatibility
you will find out that your interface is supported only on Linux.
- Real Name: Daniel Josefs
Thanks for the fast answer!
And then I would have the next problem. As soon as I select the output under Linux I get the following error message. Do I still have to install the plugin for the interface? Me or is this already included in qlc+? I found a potential plugin on the internet, but unfortunately I don't know exactly where the .ddl and .inf have to go. Can somebody help me with it? I'm just moving from problem to problem.
.ddl and .inf are windows files. Forget them
The referenced documentation ("Plugindokumentation", https://docs.qlcplus.org/v4/plugins/dmx-usb) says:
> In some cases, if the device doesn't output anything, it might be useful to add your user to the "dialout" group with the following command:
> sudo adduser your_user_name dialout
Did you try it?
What is your linux distribution?
Did you try it?
Thanks for the answer, Jano!
Ive tried it but it stil dosent work for me. Im running qlc+ on Ubuntu 23.10.
I really dont know why it wont work. Which mode do i have to choose for my Eurolite DMX512 Pro? On the moment Ive choose Pro RX/TX.
- sbenejam
My device is an Enttec DMX USB Pro.
Check if the device is there:
Check if the device is detected as FTDI USB:
sbenejam@migjorn:~$ ls -la /dev/ttyUSB0
crw-rw-rw- 1 root dialout 188, 0 de des. 17 17:59 /dev/ttyUSB0
sbenejam@migjorn:~$ tail -f /var/log/kern.log
Dec 17 17:59:42 migjorn kernel: [151244.329537] usb 1-1: new full-speed USB device number 11 using xhci_hcd
Dec 17 17:59:42 migjorn kernel: [151244.483075] usb 1-1: New USB device found, idVendor=0403, idProduct=6001, bcdDevice= 6.00
Dec 17 17:59:42 migjorn kernel: [151244.483096] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Dec 17 17:59:42 migjorn kernel: [151244.483106] usb 1-1: Product: DMX USB PRO
Dec 17 17:59:42 migjorn kernel: [151244.483114] usb 1-1: Manufacturer: ENTTEC
Dec 17 17:59:42 migjorn kernel: [151244.483121] usb 1-1: SerialNumber: EN145748
Dec 17 17:59:42 migjorn kernel: [151244.488943] ftdi_sio 1-1:1.0: FTDI USB Serial Device converter detected
Dec 17 17:59:42 migjorn kernel: [151244.489028] usb 1-1: Detected FT232R
Dec 17 17:59:42 migjorn kernel: [151244.490034] usb 1-1: FTDI USB Serial Device converter now attached to ttyUSB0
The Eurolite adapter is not FTDI. It's built with a Microchip IC.
idVendor=04D8 and idProduct=FA63
If it doesn't appear with those VID/PID then it's another device and it's not recognized/supported.
- Real Name: dominik
Hi
mine is a Eurolite DMX512 Pro MK2
it works
Bus 005 Device 014: ID 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC
journalctl -f
Dez 23 21:08:08 asock2020 kernel: usb 5-1.1.1: Detected FT232RL
Dez 23 21:08:08 asock2020 kernel: usb 5-1.1.1: FTDI USB Serial Device converter now attached to ttyUSB0
Dez 23 21:08:08 asock2020 mtp-probe[158207]: checking bus 5, device 15: "/sys/devices/pci0000:00/0000:00:08.1/0000:38:00.4/usb5/5-1/5-1.1/5-1.1.1"
Dez 23 21:08:08 asock2020 mtp-probe[158207]: bus: 5, device: 15 was not an MTP device
Dez 23 21:08:08 asock2020 snapd[833]: hotplug.go:200: hotplug device add event ignored, enable experimental.hotplug
Dez 23 21:08:08 asock2020 mtp-probe[158243]: checking bus 5, device 15: "/sys/devices/pci0000:00/0000:00:08.1/0000:38:00.4/usb5/5-1/5-1.1/5-1.1.1"
Dez 23 21:08:08 asock2020 mtp-probe[158243]: bus: 5, device: 15 was not an MTP device
Dez 23 21:08:12 asock2020 ModemManager[994]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:08.1/0000:38:00.4/usb5/5-1/5-1.1/5-1.1.1': not supported by any plugin
Dez 23 21:09:22 asock2020 kernel: ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
Dez 23 21:09:22 asock2020 kernel: ftdi_sio 5-1.1.1:1.0: device disconnected
on manjaro
does this help?
it works
journalctl -f
on manjaro
does this help?
