in QLC+ 5 Virutal ConsoleI don't get how to connect a single slider to any lights/fixtures?
If I am in Virutal Console adding a slider and trag the slider to page 1.
If I double click -
Settings opens and I can name the slider - some colors....
BUT where can I bind the slider to any fixture?
Function Control - Attribute is empty...
I don't get it at all...
how to bind slider or button to fixture in Virutal Console?
Hi, if you you're speaking about a simple rig and you want to experiment with something more flexible,
you can start by preparing your scenes using groups instead of the fixtures, then you will be able to use the same file for different venues.
It can be a base to build up your projects, here an overview of the actual situation in v.5
viewtopic.php?p=71051#p71051
