Chauvet DJ - GigBAR MOVE + ILS 50-Channel
The difference between the 50 and 51 channel file is the "shape of the laser" setting in DMX. If you download the new firmware it will add the 51st channel. I've added the 50 channel file to this post but I would recommend using the firmware upgrade and getting the 51st channel added. The link below will take you to the Chauvet website and if you scroll down to the bottom you can get the firmware update.
https://www.chauvetdj.com/products/gigbar-move-ils/
- Real Name: Henry Hitchcock
- Chauvet-GigBAR-Move-+-ILS.qxf
- (14.08 KiB) Downloaded 60 times
Rejected.
1) where are 3 and 29 channel modes?
2) there is already a GigBAR Move definition. Can't you just update that?
3) for compatibility add also 51 channel mode
