keyboard shortcuts
fedemgh
Real Name: Federico
Hello community, I'm putting together a map of keyboard shortcuts, because I haven't found it anywhere. neither in the user manual, nor in this forum.
I put this mapping together trying, but I don't know if it is complete.
I offer it to anyone who thinks it can be useful. And also so that it can be completed with your knowledge. :)
this mapping was created with qlc 4.12.7 on linux mint, but I assume they work on windows too
GENERAL
* Ctrl+a => select All in any active list
* Ctrl+d => Dump DMX values
* Ctrl+m => fixture Monitor
* Ctrl+o => Open workplace
* Ctrl+s => Save workplace
* Ctrl+F11 => Fullscreen
* Ctrl+F12 => switch to operate/design mode
* Shift+F1 => Help Manual
FUNCTION TAB
* Ctrl+l => add folder to active function category
* Ctrl+w => function Wizard
VIRTUAL CONSOLE TAB (in design mode)
* Ctrl+e => Active widget propertis
* Ctrl+shift+a => add new Audio triggers widget
* Ctrl+shift+b => add new Button widget
* Ctrl+shift+C => add new Cue list widget
* Ctrl+shift+d => add new speed Dial widget
* Ctrl+shift+f => add new frame widget
* Ctrl+shift+i => add new slIder matrix widget
* Ctrl+shift+k => add new knob widget
* Ctrl+shift+l => add new label widget
* Ctrl+shift+m => add new button Matrix widget
* Ctrl+shift+o => add new sOlo frame widget
* Ctrl+shift+r => add new animation widget
* Ctrl+shift+s => add new Slider widget
* Ctrl+shift+t => add new clock widget
* Ctrl+shift+x => add new XY pad widget
* shift+b => set active background color
* shift+f => set active font color
* shift+i => set active background image
* shift+o => set active font
fedemgh
Real Name: Federico
On the other hand, I find that there are shortcuts missing that I think would be useful. But I'm going to post that in the fature request
Shortcuts for main window are written in the documentation
https://docs.qlcplus.org/v4/main-window
Shortcuts for Function manager are written in the documentation
https://docs.qlcplus.org/v4/function-manager
Are you sure you have read it?
I'll add those for the Virtual Console
fedemgh
Real Name: Federico
sorry!!! I hadn't found it... my bad :oops:
Thanks for the information
