Hello
that's my first post in this forum.
I'm using QLC+ v4.12.7 and Open Stage Control v1.25.5 on Linux and Windows (QLC+ and Open Stage Control are running on the same machine)
In QLC+ OSC is set up with the ports from OSC Server, I can create buttons or fader and map these to the virtual console, this all works fine.
What is not working is the feedback from QLC+ to Open Stage Control, so for example if a fader is changed in the virtual console on the OSC Web Interface it's not changing.
The Controls that are created in OSC have all the default values in the configuration.
In QLC+ the feedback is enabled and the output port set to the "osc-port" of the OSC Server.
Is there a small and easy to understand tutorial how to set this up or is this function not available?
with best regards
QLC+ feedback to Open Stage Control
Possibly a duplicate of this:
viewtopic.php?t=16461
