As promised in numerous threads, I'm digging deep into the 16b MSB/LSB issues.
Issue #3 chaser has 2 scenes - with minor course and substantial fine values differently.
Took me some time to debug and visually show the outcome 8-/
Project is attached,
* 1 scene with a mover which has fine tile/pan capabilities. Set fine value different than the course value.
*clone this scene
*alter one scene and clearly differentiate the fine (LSB) value)
*add these to a chaser
in the preview, the beams clearly follow their set path
*go produce
*plays with the 2 scenes (inside a solo frame) -> beam follows set course between the scenes
*press play to chaser
Issue #3: After a while mayhem occurs on stage: LSB values in-differentiate between course and fine values present in the scene settings
Check the DMX monitor and have a look at the video what is going on now
https://youtu.be/GHrIaEb9jDo
16b tilt/pan #3 - chaser steps thru - mayhem in LSB
- PTissue4.qxw
- (4.42 KiB) Downloaded 121 times
