Global Listening for Keyboard Shorcuts
MerchantMage
Real Name: Claus
I'd like a setting to make the software respond to keyboard shortcuts globally. Meaning, that keyboard shortcuts will still work even if the software is in the background.
Mcallegari suggested I use seperate software to handle my audio and I think he had a good point.
To work with additional software effectivley though, keyboard shortcuts need to work regardless of what program is active. :)
This a paradox ... this cannot be done ... Say you have 5 applications open, and you press [CTRL]+[C]; this would ask for all applications to copy selected fields to the clipboard. Then the question is: what would you expect to get when you do [CTRL]+[V]?
Use a very cheap midi device and your problems are gone.
