A technician friend of mine bought this fixture https://es.aliexpress.com/item/10050050 ... pt=glo2esp. He left me a few days to test and make run it with QLC+. The paper manual that comes with the fixture is not correct, in the Shehds website the manual https://ueeshop.ly200-cdn.com/u_file/UP ... e135df.pdf is not correct.
I found a definition in Open Fixture Library but it's not quite complete only have the 10 channel mode and it's not right. On the same page I found this other definition from another Shehds model https://open-fixture-library.org/shehds ... a-uv-light. I tested it and it looks like 6 and 10 channel modes are the right ones with all special functions. This definition has a 9 channel mode that this fixture does not have. Modes 6 and 10 channels works perfectly with this fixture. I made some changes to the fixture definition physical properties downloaded from Open Fixture Library leaving the 9 channels mode for now.
SHEHDS Aluminum Alloy LED Flat Par 18x18W, RGBWA + UV
- sbenejam
- Shehds-LED-Flat-Par-18x18W-RGBWA+UV-Light.qxf
- (4.29 KiB) Downloaded 121 times
Added, thanks
- sbenejam
Hi Massimo, I don't know what is happening with this fixture after update and build QLC+ 4.12.8-GIT. The fixture aliases are not working as expected with fixture definition included in QLC+ with the custom definition works as expected. See the attached image. The first fixture is not changing the channel 10 to Function Speed as the custom fixture definition that I posted is working properly.
- sbenejam
I found the error. The channels modes where renamed from 10-channel to 10 Channel. The aliases keep old mode names that don't match with the renamed mode names.
<Alias Mode="10-channel" Channel="Color Presets" With="Function Speed"/> change it to
<Alias Mode="10 Channel" Channel="Color Presets" With="Function Speed"/> to get it working.
