Hi all,
Today I received the two devices I bought some days ago.
I installed the Driver for the Eurolite USB-DMX512Pro Interface Mk2.
I connected it but I don't see it on the list of available Input devices.
I selected what I thought it was "similar", but nothing happens.
Note that the Led on the Eurolite still remain Red. I suppose it should be Green.
I also connected the Kork Nanocontrol2 on anothe USB port.
First the Auto detect (to assign controls) doesn't work. But manually selecting them I see the assignement but when using button and sliders noting happens in the VC.
Please let me know how to solve both problems.
See attached images.
Eurolite USB-DMX512Pro Interface Mk2 and Korg NanoControl2
- Real Name: Paolo Betti
https://www.qlcplus.org/discover/compatibility
See the note:
in your screenshot it's not even listed.
Also, assign an input profile to it otherwise it's difficult to know which button/fader is which
See the note:
As for NanoKontrol it works out of the box.Protocol must be forced to "Pro RX/TX"
I understood that the Protocol must be Force to "Pro RX/TX" but as you can see in the images it is available only the Output check box.
Please be more specific.
Many thanks.
Many thanks.
Paolo
Hi, I found where to set the Pro RX/TX and now everything is working just fine.
Sorry to have disturbed you all for nothing.
Many thanks.
Best regards.
Many thanks.
Best regards.
Paolo
