Webserver suddenly stop working
mungle
Real Name: Luca R
Hello!
Sometimes while using the Virtual Console from an iPad using Safari the web server stop working.
I have to restart every time via SSH with:
sudo service qlcplus restart
QLC+ RaspiOS Bullseye 20230519 installed on a RPI 3
Suggestions or ways to debug?
Do you loose your network connection?
If you suspect a loss of connection, can you still ping the Raspi?
And I suppose you are using a Wifi network on both?
mungle
Real Name: Luca R
Thank you for your reply. The iPad uses WIFI, the RPI is connected via LAN and, as mentioned, I can reach it via SSH when the web server is down.
It’s headless so not connected to any screen, mouse or keyboard. I uploaded the project via browser and I only use the Virtual Console.
Does your project involve RGB matrixes and or EFXs?
It might be that the Raspi is running too hot and closes the QLC+ process.
