Hi guys,
I need a final hint to get my LED PARs triggered velocity sensitive by the edrum MIDI messages.
So, can trigger them in button mode. Working fine. Some scences in a soloframe + kick and other drums as buttons outside of that frame.
Today I learned, to get a velocity sensitive triggering together with fading I have to use a frame with a fader in submaster mode plus any function.
But I didn't get it. What is the exact config to trigger a LED PAR chaser (with fade, I like this kind of after glow effect when hitting) but velocity sensitive.
Thanks a lot for a short comment, mates!
I only got to threads with "edrums" and a few with "drums" and/or "velocity"?
That's strange. I love blinking lights!
eDrums triggering lights velocity sensitve
Sensitive means adoptable, adoptable means setting the fade-out time. Setting a fade out time dynamically is done by the Speed Dial widget.
So what if you create a slider on your VC and add the midi input to that ... does this slider react on velocity messages? If so, then a little Loopback Magic could set the Speed Dial and this would influence the fade-out time of a function.
But now I'm a little worried that all will come in time. Setting a fade-time after a function is called ... I'm not sure it will respect the changed time when the function is released again.
Perhaps a submaster linked to velocity?
