stop and restart pan or tilt with script
karimi6150
Real Name: mohammad
Hello to all
Is it possible to stop the activity of a moving channel with a script, for example, pan or tilt?
And the code that restarts it
What did start the pan tilt movement?
Like a pause function?
If it is time-based, could you set its speed to zero and reset the time again?
karimi6150
Real Name: mohammad
GGGss wrote: Mon Jul 17, 2023 6:32 am What did start the pan tilt movement?
Thank you very much GGGss
I had already tried infinite time, but after resetting time, all pans and tilts had fade, but I think I don't have this problem with time 0.
karimi6150
Real Name: mohammad
I was able to do this using loopback. And I stop and start each moving individually, but there is still some bugs, especially if we double-click on the stop button by mistake.
I am attaching the program file along with the fixtures and profiles so that other friends can check and maybe they can fix the bugs.
The text was translated with Google Translate, I apologize if the translation is not perfect.
test.rar
(7.58 KiB) Downloaded 209 times
