[Originally posted by Marcus]
Hi All,
I'm new to Q Light Controller Plus and was wondering if someone can help me with a fixture file for the American DJ Inno Spot PRO. The manual can be found at http://adjmedia.s3-website-eu-west-1.am ... %20Pro.pdf
I hope someone can help.
Have a great day!
Marcus.
American DJ-Inno Spot Pro
Here's the fixture provided by RODOLFO
- American%20DJ-Inno%20Spot%20Pro.qxf
- (6.26 KiB) Downloaded 101 times
Rodolfo, physical information and power consumption are missing.
Also, if you are grabbing fixtures from the Avolites D4 Personalities library, please don't ! They're covered by Avolites copyrights.
ok update done
I actually uses the information D'avolite, Hog, grandMA 2 Sunlite and documentation to bring me as close to the device.
Best Regards
Best Regards
American Dj INNO SPOT PRO
- (6.27 KiB) Downloaded 111 times
Rodolfo, I reveiewed this fixture. Please follow the manual and don't invent things.
- as already asked, for "Open gobo" use others/gobo0022
- shutter channel:
- wrong interval 0-7 that you called "Closed" while in the manual is called "blackout"
- interval 140-181, again invented name
- interval 182-189, completely missing
- interval 190-231, invented name
- interval 248-255, wrong (you did 255-255)
- channel 13: invented name. It's "Movement speed" and not "P/T Speed"
- channel 14: invented name. It's "Blackout/Reset" and not "Control"
You know, it shouldn't take this much to review a fixture. I shouldn't go this deep because lots of mistakes.
Do not rush to post a new fixture online. This is not a race and you don't win a medal.
Please take your time and be more accurate with what the manuals say.
Thanks you
- shutter channel:
Thanks you
Hi guys,
Try this. I've removed the gobos altogether as there are none that completely match. For example, there is no cobweb which the included gobo clearly is. I don't have time to create images at the moment.
- (6.38 KiB) Downloaded 98 times
Boxy, I just committed my reviewed version
https://github.com/mcallegari/qlcplus/b ... ot-Pro.qxf
And this made me realize that even the file name is wrong ! Gonna fix it.
- (6.56 KiB) Downloaded 92 times
