Beamz LCB244
BjornRoesbeke
Real Name: Bjorn Roesbeke
Description
The LCB244 is a LED bar with 4-in-1 RGBW LEDs. The unit is divided in 8 separately controllable sections. While using the fixture in stand-alone mode there are 12 pre-programmed shows that you can run automatically or sound activated, pick from the pre-set colour macros or create your own mixture of colours in RGBW mode. The extra IEC output enables you to simply link the power of multiple units together into a single socket. Convection cooling for noiseless operation!
Source: https://www.beamzlighting.com/product/l ... ar-24x-4w/
Specifications
  • 24x 4W 4-in-1 LEDs
  • RGBW Colour mixing
  • Colour presets
  • Pre programmed shows
  • Electronic Dimming: 0 – 100%
  • 6, 9, 16, 30 or 58 DMX channels
  • DMX and Stand-alone mode
  • Master/slave function
  • Sound activated with adjustable sensitivity
  • Auto mode with adjustable speed
  • DMX in/output via 3-pin XLR
  • Control panel with LED display
Manufacturer's documentation
Channel list
User manual, multilingual
Download definition
https://shared.bjornroesbeke.be/qlcplus ... LCB244.qxf
SHA256 hash: f32a8032cfc477cff0804e07404731244e09f38a912ca0d3ca74edcd0fed1a98 beamZ LCB244.qxf
Or alternatively via the attached file in this thread.
Notes
If required for acceptance or testing purposes, i can set up a surveillance camera pointed at the fixture, and have the web interface of QLC+ exposed to the wide public.
I own two of these appliances.
beamZ LCB244.qxf
BeamZ LCB244 fixture definition
(14.14 KiB) Downloaded 47 times
Respond or send a PM if any of my fixture definitions contains errors.
Welcome to the forum,
Thank you for your contribution Björn.
Bedankt hé
Added, thanks
