Audio Trigger...?
Ask a question related to the QLC+ 5.x usage here.
Provide as much details as you can, especially what you would like to achieve and if available, a sample workspace of your work in progress
SubOxyde
Real Name: Joe C
"Audio Trigger" works in QLC v4, but dragging into the Virtual Console does nothing using QLC 5.0.0 Beta2. I understand this is intentional per the notes. Was hoping 5.0.0 Beta2 would have a minimum and maximum function that's missing in EMU and QLC+ 4, but it looks like the base function was pulled in its entirety for some reason.
I'm seasoned with DJing/Producing (15+ years), but brand new to DMX and have observed a lot of limitations with using an audio input source to control lighting in most software I've tried. It seems like QLC is headed in the right direction with it, I was hoping a newer version would incorporate this.
Is there any way to access an earlier beta or alpha that does support Audio Triggers aside from the latest stable? I tried searching myself but cannot locate it.
All the best,
Joe
