Audio now playing, but badly distorted
cheltgar
Real Name: Gareth
Hi
Fantastic you managed to figure out the settings to get audio out of the headphone jack on the Pi.
Just made the change, and now I get audio - however it's very distorted. Tried it on a pi3 and pi4 - still distorted. It sounds crackly and intermittent, and also as if it's playing slightly slowly. If I play the audio file with 'aplay' from the command line (with QLC+ still running), it plays crystal clear - so the audio file is ok, and also it makes me believe its not the processing power of the pi.
Im not sure QLC+ is using the same audio processing, but a. is anyone else having this issue, and b. is there anything you could suggest to try
Great work BTW - Love e QLC+ !!!
Gareth
cheltgar
Real Name: Gareth
Any ideas anyone?
I have no clue ... Maybe you should research for QT5 audio playback on raspi fora?
Landmine9446
Although maybe unrelated we are having this issue on PC; To fix one of the tracks I've had to reduce the gain on the actual file. This is not a good solution.
