Good morning.
I would like to know if it is possible with the "RGB matrix" function and the strobe model to be able to adjust the pause time between two flashes?
For example :
Off - 1 second
On - 100ms
Off - 100ms
On - 100ms
Off - 1 second
ETC....
THANKS
Strobe adjustment, RGB matrix
You could use a Sequence:
You can get yourself a Quick Start by using the "Store this Matrix to a Sequence" button in the RGB Matrix editor.
