A REAL SoundActive mode for QLC+ | LedFX Plugin
Posted: Fri May 26, 2023 6:29 am
Hi all,
There have been a number of exciting developments in another FOSS lighting program called LedFX . It's a very vibrant project and they are big fans of QLC+.
After some discussion with the project owners on Discord, I was notified that they already have a plugin in progress.
My idea was to implement this through an RGB script, however I wanted to discuss options on here.
Since this would save me a lot of money through being able to leave LED strips unattended, I'm happy to put up a sizable bounty on this feature.
Cheers.
Note: May need to be moved to feature requests
- https://github.com/LedFx/LedFx/blob/mai ... ons/qlc.py
- https://github.com/YeonV/LedFx-Frontend ... l/30/files
- https://ledfx.readthedocs.io/en/master/ ... tegrations
While this approach is a good start, what would be really cool is having the technology implemented such that it would work with fixtures mapped in groups.Basically was simple: If activated LedFx scene -> QLC+ websocket -> set Widget value (aka Vitual Console button) -> QLC+ Scene.
Could also do vice versa. If Vitual Console button activated: such as assigned MIDI key pressed, then run a Fuction: Script which was a python requests script to activate a scene through LedFx API.
Cheers.
