Web Interface On External Network
- Real Name: Bennn
Hi, I use QLC+ for all my shows and I've recently discovered the web feature for qlc+. I've managed to get it working between 2 computers however I want to run it on my phone because our control booth is not very easy access. The problem I've got is that our computers run on an internal wifi network that is not available to access on any other devices (ethernet only) so is there a way to access the qlc+ web interface on an external website that I could create / an easy way to connect to it without being on its wifi?
This is more a network-specific issue than a QLC+-related one.
Where the networks come together, there is (should be) a router.
If you forward the external (WAN) port to the internal (LAN -> QLC+) port, you should be able to access the web remote.
Building an external website and 'forwarding' commands to the QLC+ host will need a lot of development through the use of the QLC+.api.
If all this reads like a foreign language, I'm afraid I can't help you any further.
