Hello !
Hope you're doing well.
Can someone help me to create a Fixture for this light bar please ?
ALGAM LIGHTING - FLORIDA BAR
PDF of the light bar : https://algam-akeneo-prod.s3.eu-west-3. ... NUAL_2.pdf
It will be awesome
I've tried to it by myself but I did not understand how channels works, this is what I've done :
Thanks a lot
If you want to use this fixture in QLC it is better not to see it as one, but as a combination of Par-Derby-Derby-Par-Laser-Flash.
That way for instance the 2D monitor will show what the seperate components are doing and you'll be able to create separate Fixture Groups (only for the PARs or only for the Derby's) to use RGB Matrices.
Put your Florida bar in 27 channel mode and set your DMX start address.
Download the 4 QXF files and put them in your QLC User Fixture Library (in Windows it is C:\users\"your name"\QLC+\Fixtures).
Now in QLC on the Fixtures Tab add your fixture using the attached QXF files (because the number of attachments is maxed to 3, you will find the 4th in a following message).
If you used 1 as start address, you should:
- add the first PAR on address 1 (you could change the name to Florida PAR 1).
- add the first Derby on address 6 (you could change the name to Florida DERBY 1).
- add the second Derby on address 11 (you could change the name to Florida DERBY 2).
- add the Second Par on address 16 (you could change the name to Florida PAR 2).
- add the Laser on address 21 (you could change the name to Florida Laser).
- add the Flash on address 24 (you could change the name to Florida Flash).
- Algam_Lighting-Florida-Laser.qxf
- (1.63 KiB) Downloaded 92 times
- Algam_Lighting-Florida-Derby.qxf
- (1.4 KiB) Downloaded 92 times
- Algam_Lighting-Florida-Par.qxf
- (1.13 KiB) Downloaded 72 times
And the 4th one:
- Algam_Lighting-Florida-Flash.qxf
- (1.86 KiB) Downloaded 91 times
