anyone have a definition on for both uplights? i have the S6's
https://bothlightingusa.com/products/s6-1
BOTH Lighting Uplight s6
Fixture definition is almost the same as that of the Showtec Club Par 12-6 RGBWAUV, so credits should go to Santiago Benejam Torres.
Only channel 9 and 10 had to be changed.
- sbenejam
Michel, the Showtec Club Par 12-6 physical specs are very different to this fixture. I think the credits should got to you.
The physical specs might be very different, but the DMX chart is almost the same.
The trick is to find an existing Fixture definition that comes as close as possible.
Here the type of LED is relevant: RGBWA Uv, not the number of LED's, the Wattage or whether it is an Uplight or not.
As i only had to change two channels i felt a bit ashamed to claim full credits.
