Hello there!
I frequently use EFX to achieve various impressive effects for my fixtures, and I find it useful to utilize the start offset. However, determining the appropriate offset value to evenly distribute my fixtures on moving patterns can be time-consuming. It becomes especially challenging when dealing with more than ten fixtures and attempting to spread them out over 360 degrees. Calculating the necessary quantity by multiplying that number with the fixture's queue is difficult to do mentally, especially when under pressure.
It would be ideal to have a feature that automatically calculates the offsets for fixtures, allowing them to be spread evenly on the pattern and a manual offset multiplier entry option would also be helpful.
EFX Start offset calculation
I need this too. Can you guys please post some standard offsets you use? I imagine it's going to look similar to the "Fan" options in V5.
I often use 30 and 90-degree offsets but I'm often jealous of MA users who can seemingly change this value on the fly.
And you didn't mention wings, groups, offsets, ... the EFX engine in GMa is simply priceless...
Start using your EFX in relative mode. Now it comes to giving your heads a sexy start position to work with. This way you don't really have to make calculations unless you want the movements to be super tight.
My calculator allows me to do a + +. So 360/# of fixtures equals, + + doubles the value and then + + adds the first value again. (so 360/# of fixtures * 3 // *4 // *5 // etc)
MagicQ allows "all the same", spread (=all different), split in 2 groups, 3 groups, 4, up to number of fixtures.
Sounds like you have the logic worked out! Imagine if we could have a button/slider which applies those values either in the EFX itself or as part of the widget on the VC.
