Hello, I have a set of generic RGBW fixtures which I have configured in Virtual Console as Fader -> Level -> Click&Go -> RGB.
The problem is that when I open the colour selector, if I select blue QLC turns both the blue and white channel to 255 level.
If I click red or green it turns on only the correct channel and leaves the white off.
Click & Go strange behaviour with BLUE
When you did set up your fader as Level, you probably only selected the Fixture(s).
If you open the properties of your slider, open the Level Tab, find the Fixture and press on >, you will see which Channels are selected.
You only need Red, Green and Blue, if you Unbox White, it will work fine.
Of course you can.
Just create an extra slider, go to Level Mode and now select only the White channel.
Be aware that within the Click & Go Color Selector you also have the option to select White (although this will be realised by mixing Red, Green and Blue).
