Validator error - capability ordering
- Real Name: Will T
I think there may be a bug in the validator, if you list the capabilities in alphabetical order rather than numeric value the validator say you have overlapping values when you do not
- WLED-Moon-Modules-WLED.qxf
- (18.24 KiB) Downloaded 36 times
If you complete the capabilities range up untill 255 (so for Chanel Effect Picker add one more value: 188 - 255 Others), it will pass the test.
- Real Name: Will T
MichelSliepenbeek wrote: ↑Tue Apr 11, 2023 7:48 pm If you complete the capabilities range up untill 255 (so for Chanel Effect Picker add one more value: 188 - 255 Others), it will pass the test.
Thank you
- Real Name: Will T
Hi Michel, you have't actually just completed the range, you have reset the ordering of the capabilities back to numerical order, not the alphabetical order I had them in, for easy accessMichelSliepenbeek wrote: ↑Tue Apr 11, 2023 7:48 pm If you complete the capabilities range up untill 255 (so for Chanel Effect Picker add one more value: 188 - 255 Others), it will pass the test.
Will,
It wasn't me that changed the order, The Fixture Editor did that.
If your definition is correct and complete it will only present the capabilities in order of (ascending) DMX values.
In fact, that it didn't change the order before, was the trigger for me to try the extra value.
