Hi everyone,
I got a few Elation SIX PAR Z19 IP, and I'm trying to create a QFX.
I've done the best I can here
Can someone please answer my questions and check that I've done everything currectly?
1) I set the "type" as "other", as I haven't seen "LED".
2) The Lumens I put are: "13,240". This number is specifically for all lights together @ 3m, 5 degrees. Don't know if that's what I should have done...
3) I'm getting those errors. I'm guessing that it's because I didn't configure "heads"?
I haven't found in the user guide of the fixture any mention of the heads
Any clue about how can I know how many heads are they, and how to configure them?
ERROR: In mode <07CH>, channel <RED> cannot act on itself!
ERROR: In mode <07CH>, channel <GREEN> cannot act on itself!
ERROR: In mode <07CH>, channel <BLUE> cannot act on itself!
ERROR: In mode <07CH>, channel <WHITE> cannot act on itself!
ERROR: In mode <07CH>, channel <AMBER> cannot act on itself!
ERROR: In mode <07CH>, channel <UV> cannot act on itself!
ERROR: In mode <07CH>, channel <ZOOM> cannot act on itself!
ERROR: In mode <09CH>, channel <RED> cannot act on itself!
ERROR: In mode <09CH>, channel <GREEN> cannot act on itself!
ERROR: In mode <09CH>, channel <BLUE> cannot act on itself!
ERROR: In mode <09CH>, channel <WHITE> cannot act on itself!
ERROR: In mode <09CH>, channel <AMBER> cannot act on itself!
ERROR: In mode <09CH>, channel <UV> cannot act on itself!
ERROR: In mode <09CH>, channel <ZOOM> cannot act on itself!
ERROR: In mode <09CH>, channel <Master Dimmer> cannot act on itself!
ERROR: In mode <09CH>, channel <Master Dimmer FINE> cannot act on itself!
ERROR: In mode <10CH>, channel <RED> cannot act on itself!
ERROR: In mode <10CH>, channel <GREEN> cannot act on itself!
ERROR: In mode <10CH>, channel <BLUE> cannot act on itself!
ERROR: In mode <10CH>, channel <WHITE> cannot act on itself!
ERROR: In mode <10CH>, channel <AMBER> cannot act on itself!
ERROR: In mode <10CH>, channel <UV> cannot act on itself!
ERROR: In mode <10CH>, channel <ZOOM> cannot act on itself!
ERROR: In mode <10CH>, channel <Master Dimmer> cannot act on itself!
ERROR: In mode <10CH>, channel <Master Dimmer FINE> cannot act on itself!
ERROR: In mode <10CH>, channel <Sutter Strobe> cannot act on itself!
ERROR: In mode <14CH>, channel <RED> cannot act on itself!
ERROR: In mode <14CH>, channel <GREEN> cannot act on itself!
ERROR: In mode <14CH>, channel <BLUE> cannot act on itself!
ERROR: In mode <14CH>, channel <WHITE> cannot act on itself!
ERROR: In mode <14CH>, channel <AMBER> cannot act on itself!
ERROR: In mode <14CH>, channel <UV> cannot act on itself!
ERROR: In mode <14CH>, channel <ZOOM> cannot act on itself!
ERROR: In mode <14CH>, channel <Master Dimmer> cannot act on itself!
ERROR: In mode <14CH>, channel <Master Dimmer FINE> cannot act on itself!
ERROR: In mode <14CH>, channel <Sutter Strobe> cannot act on itself!
ERROR: In mode <14CH>, channel <Color Macros> cannot act on itself!
ERROR: In mode <14CH>, channel <Program Macros> cannot act on itself!
ERROR: In mode <14CH>, channel <Program Speed> cannot act on itself!
ERROR: In mode <14CH>, channel <Dimming Curve Modes> cannot act on itself!
ERROR: Global physical dimensions are missing or incomplete. Please fill them.
14 channels found. 4 modes found.
41 errors were detected. Please fix before submitting.
Thank you so much!!!
Sophia
- Real Name: Sophia
QFX is attached.
I can't upload the user guide here is it's more than 2MB ((
I'm attaching the link:
https://www.elationlighting.com/six-par-z19-ip
Thank you!!
Sophia
Thank you!!
Sophia
- Real Name: Sophia
QFX
- Elation-SIX-PAR-Z19-IP.qxf
- (8.8 KiB) Downloaded 132 times
- edogawa
- Real Name: Edgar Aichinger
1) For multicolor LED PARs etc. I usually choose "Color changer" as fixture type
2) I wouldn't loose hair about a wrong lumen number... the fixture validator doesn't complain if it's missing, and I'm not sure if or how QLC makes use of that info at all.
3) That's not because of missing heads definitions. Heads are used if your light has more than one group of light sources that can act independently (like sections in a LED Bar)
The reason is that you filled in the "Acts on" field for each mode, in the mode editor. This has been introduced a while ago, and the documentation mentions:
I don't know why everyone thinks they have to set this to the same channel, just leave it unset. This misunderstanding comes up with almost every other definition posted here, recently... I don't know how we could make it more obvious to not touch that parameter unless needed.The "Acts on" column is used to bind a channel to another. For example a channel that controls the speed of a rotating gobo.
- Real Name: Sophia
Thank you for your reply!
Now I understand...
If I may suggest, you can just add "(optional) by the "Acts on", which will make everything clearer
Now the QFX passed the validator and should be ready to go.
Thank you again for the explanation!!
Sophia
Now I understand...
Sophia
- Real Name: Sophia
QFX - passed validator
- (8.37 KiB) Downloaded 130 times
An other example for "Acts On" could be: Program Speed acts on Program Macros (Channel 13 acts on channel 12) .
You can change it if you also Change:
- your Fixture Type to Color Changer (it is mainly how it looks in the Fixture Editor)
- "Sutter" to "Shutter""
- Real Name: Sophia
Updated QFX
- (8.39 KiB) Downloaded 141 times
- Real Name: Sophia
An issue I'm having with the fixture: I set all the Z19 fixtures to "Strobbing: 255" (which means no strobbing, just steady light), but on the QLC monitor, it shows that the Z19 are blinking for some reason
Anyone have any idea why?
Thank you so much!!
Sophia
Thank you so much!!
Sophia
Added, thanks
Quite a pity for the anonymous color macros (not even the manual lists their RGB codes )
- Real Name: Sophia
QFW
- Bank24.qxw
- (179.47 KiB) Downloaded 133 times
- Real Name: Sophia
Latest version
- (8.41 KiB) Downloaded 129 times
