Hello together,
I use two EUROLITE LED FE-800 RGBAW and 4 Stairville LED Flood Panel 150 for my party cellar.
The scenes and ChaserI created for the Flood Panels work great but I have some problems with the LED Fe-800.
It's mainly about switching off in the VC.
I have created the following scenes and chasers as running lights:
Scene :
FE-800 on with all LED's (hold 250ms)
FE-800 all off (hold 250ms)
Chaser :
Step 1 : FE-800 on with all LED's (hold 250ms)
Step 2 : FE-800 all off (hold 250ms)
Then I created a switch in the VC with the link to the chaser with the function (on-off).
I can then switch this chaser on and off, which is ok so far.
Now comes the problem, when I switch off the chaser in the VC, the lamps remain on or are off, this is due to the moment (step) in which the chaser is currently.
Is there a possibility to give a signal to the lamps when switching off the chaser so that they switch off?
I hope you can understand what kind of problem I have?
Greetings from NRW
Clausi
Translated with www.DeepL.com/Translator (free version)
Questions about Scene and Chaser with EUROLITE LED FE-800 RGBAW
Seems to me you are creating a strobe? You might try to use a button in flash mode and make use of the loopback magic, to fire your chaser.
It is possible but for the novice user (or you want to learn a lot in a short time
No, it's not supposed to be a strobe, took a wrong example for that.
I create a chaser that consists of these scenes:
1. red
2. blue
3. yellow
4. green
etc.....
I link this chaser to a button in the VC.
If I press this button the chaser runs with the scenes, but as soon as I press the button again to stop the chaser, the scene stays on, if I press the blackout button the scene goes off, if I press the blackout button again the scene is back.
I hope this is described a little better understandable.....
1. red
2. blue
3. yellow
4. green
etc.....
Seems your Button works like Play/Pause instead of Play/Stop.
You should use a Cue List to control your chaser (instead of a button).
Then you can configure your Play, Pause and Stop functions (and get a lot of Timing Options as well).
am only a few days ago to read your tips and test.
I have tested with the cuelist, it does not matter what I take, cuelist or chaser, the lamps always remember the last setting, red, blue, etc. I have to give the cues or chasers a scene where all or some are off.
Another disadvantage of the lamps is that they do not have a dimmer, could also be related to this.
Thanks again for the advice, Clausi4711
Try this:
Next to the scenes for red, blue, yellow , .... also create a scene for Black (R=0, G=0 and B=0).
Next create a solo frame with 2 buttons: one to start your "Black Scene" and one to start your chaser.
Start your chaser with the "Chaser Button" and use the "Black Button" to stop it.
Hi, yes it works, thanks for the help !
