Philips/Vari-Lite ShowLine SL220 and SL Beam 100
jkazores
Real Name: JKIII
Hi I need the definitions for Showline SL220 and SL Beam 100. Thanks!!!!
SL220 Manual https://www.bhphotovideo.com/lit_files/841223.pdf
SL Beam Manual: https://www.vari-lite.com/b-dam/vari-li ... MANUAL.pdf
MichelSliepenbeek
Real Name: Michel Sliepenbeek
Here is the SL Beam 100.
If someone else wants to pick up the SL220, Please!!!
These fixtures have a lot of modes and channels.
Showline-SL-BEAM-100.qxf
(16.56 KiB) Downloaded 45 times
MichelSliepenbeek
Here is the other one.
This one turned out to be easy, only had to remove all the pan and Tilt related channels from the SL Beam 100 Ficture Definition.
Showline-SL-PunchLite-220.qxf
(15.53 KiB) Downloaded 47 times
jkazores
Real Name: JKIII
Thanks!!!!!!
jkazores
Real Name: JKIII
I've tried everything and cant seem to get these definitions added. I tried to copy them into the fixtures folder and Ive tried opening them in the fixture editor and doing a save as and nothing is working. Im on windows 10 and using qlc+ 4.12.6
After you copied the files to your user-fixture-folder (c:\users\[userx]\QLC+\Fixtures), did you restart QLC+. It is only at the start of QLC+ the list of fixtures gets refreshed.
Then with the filter you can search for 'Showline' as the manufacturer or more direct 'punchlite'
ScreenHunter_40 Mar. 06 12.45.png (9.39 KiB) Viewed 1245 times
MichelSliepenbeek
As the provider of this Fixture Profile i felt the need to give it an extra check :) ;)
If you put it in the folder like Fredje explained, it should work.
Having another look at it however, i found a mistake that i missed before. :x :?: :!:
The SL220 is not a Moving Head but a Color Changer.
Use this one:
Showline-SL-PunchLite-220 (2).qxf
(15.54 KiB) Downloaded 48 times
