Here you will find a fixture definition for the Varytec LED BAR 240-8 CW-WW (which is also sold as Stairville LED BAR 240-8 CW-WW).
It is based on the definition of the Stairville Led Bar 240-8- RGB, so credits should also go to to Mikko Toivonen.
As the fixture has separate channels for Warm White (WW) and Cold White (CW) but the QLC+ engine does not make a distinction between those "colors", i have created two versions:
- the "purist version" where both the CW and WW channel are defined as White and
- the "practical version" where WW is defined as Amber and the CW as White. If you use the RGB Matrix functions you then can select between White (= CW) and Amber (= WW).
- Varytec-LED-BAR-240-8-CW-WW.qxf
- (5.52 KiB) Downloaded 65 times
- Varytec-LED-BAR-240-8-CW-WW (WW as Amber).qxf
- (5.53 KiB) Downloaded 55 times
Added, thanks
