I'm using ableton with IAC drive to control QLC+ (v4.12.6), on 2 MAC. I need to keep control on QLC also with my controller (AKAI APC40 MK2)
On my laptop, It works perfectly, Messages midi from ableton control QLC via IAC, and my APC40 works at the same time, i can control and launch scene.
On my other mac, with the same settings in ableton, plc, midi config, it doesn't works.
In your opinion, where is the problem ?
Thanks !
Ableton IAC + midi controller
If you loaded your show on another machine it'd be worth double checking your inputs and outputs.
My other suggestion would be to try starting the programs in a different order.
Can you give us any additional information about what you've got setup? Any other midi devices being used?
