Hi All, I am a complete noob when it comes to QLC+ / DMX etc. but as an art project / proof of concept I am looking for a solution that can support the scenario where I want to be able to visualize the intensity of different sounds at the same time using coloured lights.
The test case that I want to implement is based on playing 3 wavs/tracks synchronously (from QLC+?) and accompany the sounds individuallly with 3 different coloured lights that change intensity based on amplitude/intensity per sound track (using audio triggers??)
Is there by any chance that this scenario can be implemented using QLC+?
I have attached a screenshot of a sketch that illustraties what I would like to achieve.
Synconously play different tracks and control lights per track
Welcome to the forum,
Synchronously as in 'at the same time'?
Piano and vocals frequencies will overlap; hence your audio-to-light detection will be off. So NO
Piano and bass frequencies will overlap; hence NO
For this to work you would need 3 audio sources and 3 spectrum analysers. I'm not sure QLC+ can use 3 different audio sources for the audio widget. That is: the audio will have to be played elsewhere (on another computer). QLC+ isn't capable of analysing the audio files it plays itself.
I reckon I have a workaround for you. You could try and run multiple instances of QLC+ and use a different audio source in each.
Send all the data to Artnet, then use a passthrough universe in one of the instances of QLC+ to output to your OpenDMXUSB.
Let me know how it goes!
Negative, QLC+ isn't able to select the audio source in detail. You can select the device, but not the channel f.i.Yestalgia wrote: ↑Sat Feb 11, 2023 12:53 am I reckon I have a workaround for you. You could try and run multiple instances of QLC+ and use a different audio source in each.
Quickly tried it with Focusrite Scarlet 18i20 on Windows
- sbenejam
On Ubuntu you can create many virtual devices to route audio signals as you need. In QLC+ you can set this audio devices to an specific audio track and connect this virtual devices to the desired outputs, insert effects and more.
