HTP check not passed for a specific chanel
Sp4rKy
trying to debug another issue (with midi controller) I saw that qlcplus prints a lot of debug line with message:
"[Universe] HTP check not passed 145 30"
Looking at the source code I noticed first number is channel, second is value. Channel 145 is part of a fixture using a custom profile I did (rgbwauv 10 channels). However:
* I have 4 fixtures with the same profile, only this specific channel is raising error
* If I change address of this device to, let's say, 60, errors stop. If I put it back to 140 (as base channel) , then it starts again
What's wrong with this number ? :D
Sp4rKy
Mhh, so after more test I saw it finally also raise the issue on the 6th channel of this fixture when i change it's addresse, but no issue on any other features / channel
Sp4rKy
not sure what happened with this fixture, but i finally deleted it and re-add , which fixed it.
