Equinox Fusion Spot XP
MaxDee
Real Name: MaxDee
Hi all
I have just started using QLC+ and not very confident in creating new Fixtures yet.
I would appreciate if someone could create 10 Channel mode for Equinox Fusion XP for me.
Manual can be found here:
http://www.prolight.co.uk/ftp-in/EQLED004_Manual.pdf
and the fixture information here:
https://prolight.co.uk/product/fusion-spot-xp
Thank you in advance!
It's not at all problematic.
Use the Contest Mini-head 10W as an example.
I want to help you create (or modify) the profile, but only you can define the correct gobo images...
MaxDee
Real Name: MaxDee
Hi, I have no preference in the gobo order so if they are set as per instructions manual I would be happy!
Thank you
Musikjens
Real Name: Jens Fischer
Hi MaxDee
I hope it suits you.
Equinox-Fusion-Spot-XP.qxf
(4.97 KiB) Downloaded 58 times
MaxDee
Real Name: MaxDee
That's great, I ll have a play at the weekend. Thank you so much!
MaxDee
Real Name: MaxDee
Thank you it worked perfect
