I am searching for a way to convert an analog audio input into a beat signal that I can use in QLC+.
I know that this is possible with Virtual DJ but I’m trying to do this on a RaspberryPi (and I am not a programmer).
As the DJ setup is analog, there is no midi signal to use and the audio analyzer from QLC+ is not reliable/clean enough for my purpose.
Is there any software for my RPi 4 or a small device to connect to the RPi that can extract the beat of the music and send a signal?
Thanks in advance
Setup to extract beats from live audio and feed it to QLC+ on RaspberryPi 4
You might use the audio input on the Raspivroomvroom wrote: ↑Mon Dec 19, 2022 7:50 pm Hello,
Thanks in advance
Set up an audio widget and detect those beats
It might work for you - check the chaser feature in QLC+
My TopTip: use a main chaser (16+ bars) with sub-chasers (1-2-4 bars) in a sequence ... 'next' trigger based on your audio widget input.
This would involve some loopback-magic to work though
- Real Name: Vroom Vroom
Thank you
I will try the audio widget with the chasers. I have some concerns but I can give it a shot.
