Chauvet DJ Intimidator Beam Q60
Tooters
Real Name: Nathan
Hello wonderful volunteers :)
If somebody would create a profile for this fixture I would be very very happy!
https://www.chauvetdj.com/wp-content/up ... M_Rev3.pdf
Thank you! Have a happy day
Welcome to the forum.
hmm ... nifty fixture you have sir.
Continuous channels are not included inside the fixture editor NOR the virtual color wheel.
I'd suggest you pick a wash fixture and change the fixture channel attributes to your likes and outcome.
I would do it like that.
Fixture editor help is here: https://www.qlcplus.org/docs/html_en_EN ... ditor.html
Tooters
Real Name: Nathan
Okay sounds reasonable. I won't be using the virtual color wheel so that's no issue.
I will make a profile myself and post it!
Tooters
Real Name: Nathan
Here is the fixture profile I ended up making. I did not fill in the information for the virtual color wheel & color wheel control channels, as I will not be using them and there is a lot of information to cover! Otherwise seems to work very well, although I am encountering a bug where the continuous pan/tilt channels seem to override the normal pan/tilt speed channel, and then I cannot regain speed control without a show restart. Though I suspect that is a bug within the fixture and not QLC+...
Chauvet-DJ-Intimidator-Beam-Q60.qxf
(5.99 KiB) Downloaded 34 times
You have to make those channel LTP. If a higher value cannot be 'overwritten' that means that HTP kick in. Pan and Tilt (and gobos etc) always LTP.
Latest Takes Precedence versus Highest Takes Precedence.
