Downloaded QXW files crash QLC+
- Real Name: Ken Coughlin
Just something I 've noticed recently. I often download workspaces to see if I can figure out the problem a user has with their QXW workspace file. In the past, they usually loaded fine, but recently, it seems most of the workspaces cause QLC+ to crash, at least on Windows10 x64, using 4.12.6.
Can you please point us to one that is crashing for you? Thanks.
- sbenejam
How do you open the workspaces, directly from your browser?. Or from Downloads folder?
The audio.qxw file in this post:mcallegari wrote: ↑Tue Nov 08, 2022 8:05 am Can you please point us to one that is crashing for you? Thanks.
viewtopic.php?f=22&t=15924
I downloaded the file mentioned above, moved it into the QLC+ folder, ran QLC+, clicked the Open icon, scrolled down and clicked on the file name, then clicked OPEN.
QLC+ closes immediately, and creates the following Event Log entry
Faulting application name: qlcplus.exe, version: 0.0.0.0, time stamp: 0x630a2689
Faulting module name: qlcplusengine.dll, version: 0.0.0.0, time stamp: 0x630a24d5
Exception code: 0xc0000005
Fault offset: 0x00081362
Faulting process id: 0x1e58
Faulting application start time: 0x01d8f3c30dcc63c8
Faulting application path: C:\QLC+\qlcplus.exe
Faulting module path: C:\QLC+\qlcplusengine.dll
Report Id: 89835ffa-eae6-4cab-8bea-5ab4eff9691c
Faulting package full name:
Faulting package-relative application ID:
This one crashes for me also - editing the mentioned project file with a text editor and removing the pointer to the USB interface in the interfaces block, it opens normal now.
I don't recall having to do that in previous versions. It will make it harder to test project files going forward, if each of them have to be edited in a text editor before testing them.
Doesn't crash for me on Linux.
So I guess this might be specific to Windows.
[EDIT] doesn't crash on Windows too. Tried with and without a DMX USB adapter. What am I missing?
