Good evening everyone, as written above I bought the EUROLITE PoE ART-NET NODE I device but I realized that it is not good and it does not work. I do not understand why, I tried to set it in all ways but nothing to do, the sth tells me that it exchanges packets, in fact I see that the dmx signal is there but the dmx lights do not turn on. How come? I used to use a simple unbranded artnet peripheral and everything was fine, why not with this new device? I await your many thanks.
https://www.steinigke.de/de/mpn70064854 ... ode-i.html
Sorry to hear you're having troubles.
It looks like a nice made in Germany product. Probably comparable with the nice ENTTEC ones we have here in Aus.
Can you confirm it's plugged into a PoE port on your switch?
Cheers,
Lachie
Cheers,
Lachie
Also QLC+ automatically assigns the Artnet universe to the "universe number" in your input/output patch.
Try double clicking the artnet plugin to see what universe it's putting out and match it with what the artnet node is listening to.
Hi Lachie, yes the product is well made and the cost is very low unlike the others which are really very expensive, I am a small dj with few dmx lights and during the holidays I have to check them
So I need an ARTNET peripheral to control them for me, plugged directly into my computer, that's all, no switches. I don't need the POE function, in fact it is used with external power supply. How come QLC sees it, dmx output cue to IP but no dmx signal comes out?
What artnet universe do you instruct QLC+ to send out?
And what artnet universe is bound to the physical XLR output?
Have a look at the configuration page of the node.
Hi, all about universe 1, having few lights I have never added or changed universe, this is the strange thing, that's why I don't understand what I'm wrong and why EUROLITE tells me about lack of compatibility
Okay,
Here's a link to the manual: https://www.steinigke.de/download/70064 ... -de_en.pdf
Try the following (Assuming no switch/router between your computer and the node)
- Set the IP address of your computer's ethernet port to 192.168.1.10 and subnet mask 255.255.255.0
- Access the node via the Web @ http://192.168.1.20
- Make sure the settings match with the image
- In QLC+ select ArtNet "192.168.1.10" as the output for universe 1
- Double Click ArtNet "192.168.1.10" to configure the Artnet Universe to 1
