Crash with audio function
dvthomas
Real Name: David THOMAS
Using QLC+ 4.12.6 on a mcbook pro with MacOS 12.6, i've been facing a crash when deleting an audio file.
First : I created a qxw file with a lot of functions. I added an audio file for 1 case (used in the show manager)
Then : I wanted to remove this audio file, not necessary used on other shows. each time I tryed to delete it from the functions tab QLC crashed.
Workarround : I opened the qxw file with a text editor and deleted the few lines surrounding this audio file.
If this can help for development process.
If you need some technical details don't hesitate.
Regards
kenact
Real Name: Ken Coughlin
I just tried this on a Windows 10 laptop, and it worked. No crash.
Created a Show
Added a track
Added mp3 audio file to track (not previously in the project)
Added a scene track
Switched to Functions tab
Selected audio file (initial focus set to name)
Clicked audio file a second time to set focus
Click Delete
Confirm delete
Click Show tab
Audio file is gone
rew45
Real Name: Richard Wenham
QLC 4.12.6
Windows 7, Windows 10, Linux Mint 21
I have the same problem under Windows 7, QLC+ crashes if you use the Toolbar Delete icon (red X), but if you you right-click on the audio function and use the Delete from the menu thus displayed, then the audio is deleted as expected. I don't get the problem under Windows 10 or Linux.
Richard
ljack
Real Name: Jakob
Just wanted to confirm that this crash also happens with QLC 4.12.6 on Mac.
For some reason it doesn't happen with all audio functions. Some will delete without a problem with the red X in the toolbar, others crash consistently.
But thank you so much for the hint/workaround with the context menu, it works great!
ljack
Real Name: Jakob
Thank you, Massimo!
With 4.12.7 the red X in the toolbar works as intended, audio functions that crashed 4.12.6 now can be deleted without a problem! :D
