v.5 scene editing: copy between fixtures
Posted: Thu Oct 20, 2022 10:26 am
by giacomo
in v.4, scene editing, is possible to copy the fixture values to other fixtures,
can we add this function in v.5 too?
it will help a lot the scene editing, thanks.
Re: v.5 scene editing: copy between fixtures
Posted: Wed Feb 22, 2023 8:50 am
+1 for me - essential functionality
Posted: Thu Feb 23, 2023 7:11 pm
by ShagLight
Yes! 4xx has that feature but is sorely missing in 5.
Posted: Thu Feb 23, 2023 10:01 pm
by Yestalgia
Good point, probably needs to be in the roadmap spreadsheet.
Posted: Mon Dec 11, 2023 5:49 pm
by giacomo
hi guys, I've found a partial workaround for v.5:
when editing a scene, you've to select all the fixtures that you want to copy, on linux with CTRL click, then in 2D you can control globally the parameters exposed by the widgets.
Unfortunately many parameters are not reachable in this way but it's already something and you can also play the scene while doing the changes.
It would be good to have a copy command for fixtures in 2D view to use not only for editing.
On the contrary, when you modify a parameter with the slider in the scene fixture list, the corresponding widget won't update to the actual value, it's been already reported.
