Wrong assignments of sliders after remapping
Posted: Tue Oct 18, 2022 10:13 pm
by offit
After performing a fixture remapping, some of the sliders of the virtual console are assigned a wrong fixture/channel.
I tried to reproduce the error on a simplified workspace but I couldn't. So I attached my real project file that has been growing for months and that I use for performing live with a band that I follow.
The remapping was like this : I cloned all the fixtures on every universe but only 4 fixtures were changed (SPOT BACK #1-4 on Universe Venue). The fixture stays of the same type, only the mode changed (14 to 17 channels).
As I start using the remapped workspace, I noticed some incoherent behaviours. I found that the knobs on my MIX panel had been assigned a wrong fixture. For example the <Slider Caption="L" ID="19" WidgetStyle="Knob" ...> on the original workspace (line 20461) is level fixtures 25ch0 (Front Spot #1) and 26ch0 (Front Spot #2). On the remapped workspace (line 20360) the same knob is level fixtures 47ch0 (SPOT BACK #4) and 48ch0(SUNSTRIP #1). The remapped workspace is unusable unless I go through all the programming and check for correct values which is impossible before the show starts !
Is there a problem with my original workspace file or is this a bug in the remapping code ?
QLC+ Version 4.12.6 / Ubuntu
Re: Wrong assignments of sliders after remapping
Posted: Mon Oct 24, 2022 5:05 am
by offit
Found the bug. The slider is listed twice for remapping in the code at FixtureRemap::accept() : 6 - remap Virtual Console widgets
I will submit a pull request.
Posted: Wed Nov 02, 2022 8:29 pm
by offit
Here is a simplified project that reproduce the bug.
