Hi
I couldn't see a specific forum for this problem so apologies if this is the wrong place, all though I getting this problem as I am setting up a show using virtual conole
I have a macbook pro retina mid 2014 - 8gb Memory Running Big Sur and the latest build of QLC+
All is fine - and then, for no reason the computer just suddenly crashes.
This is the error report
Does anyone have any ideas what causes this? (I can see that QLC is called at as part pf this system crash report)
Thanks in advance
All the best
Tony
panic(cpu 3 caller 0xffffff801f0a12ee): "No more room to grow table: 0x0xffffff8020075a00 size:262142, used:262141, requested elem:1"@/System/Volumes/Data/SWE/macOS/BuildRoots/37599d3d49/Library/Caches/com.apple.xbs/Sources/xnu/xnu-7195.141.39/osfmk/kern/ltable.c:494
Backtrace (CPU 3), Frame : Return Address
0xffffffa0999ebad0 : 0xffffff801f08a21d
0xffffffa0999ebb20 : 0xffffff801f1d1f43
0xffffffa0999ebb60 : 0xffffff801f1c253a
0xffffffa0999ebbb0 : 0xffffff801f02ea2f
0xffffffa0999ebbd0 : 0xffffff801f089a3d
0xffffffa0999ebcf0 : 0xffffff801f089d33
0xffffffa0999ebd60 : 0xffffff801f89beaa
0xffffffa0999ebdd0 : 0xffffff801f0a12ee
0xffffffa0999ebe30 : 0xffffff801f0e1fc4
0xffffffa0999ebe50 : 0xffffff801f07f824
0xffffffa0999ebec0 : 0xffffff801f07b658
0xffffffa0999ebef0 : 0xffffff801f1a660d
0xffffffa0999ebfa0 : 0xffffff801f02f216
Process name corresponding to current thread: qlcplus
Mac OS version:
20G817
Kernel version:
Darwin Kernel Version 20.6.0: Mon Aug 29 04:31:06 PDT 2022; root:xnu-7195.141.39~2/RELEASE_X86_64
Kernel UUID: 36422EC9-C3B4-3EEC-AE96-AADD49023F13
KernelCache slide: 0x000000001ee00000
KernelCache base: 0xffffff801f000000
Kernel slide: 0x000000001ee10000
Kernel text base: 0xffffff801f010000
__HIB text base: 0xffffff801ef00000
System model name: MacBookPro11,1 (Mac-189A3D4F975D5FFC)
System shutdown begun: NO
Panic diags file available: YES (0x0)
Hibernation exit count: 0
System uptime in nanoseconds: 7453560816817
Last Sleep: absolute base_tsc base_nano
Uptime : 0x000006c76ad848f4
Sleep : 0x0000000000000000 0x0000000000000000 0x0000000000000000
Wake : 0x0000000000000000 0x0000001efc47067f 0x0000000000000000
last started kext at 49138063224: >!AUpstreamUserClient 3.6.8 (addr 0xffffff7fb9c24000, size 12288)
last stopped kext at 257230061186: >!ASMBusPCI 1.0.14d1 (addr 0xffffff7fb9b33000, size 4096)
loaded kexts:
com.spotflux.Spotflux.tun 1.0
com.Cycling74.driver.Soundflower 2
>!APlatformEnabler 2.7.0d0
>AGPM 122.1
>X86PlatformShim 1.0.0
@fsplaceholder 1.14.0
@filesystems.autofs 3.0
@fileutil 20.036.15
>AudioAUUC 1.70
>!AGraphicsDevicePolicy 6.3.6
@AGDCPluginDisplayMetrics 6.3.6
>pmtelemetry 1
|IOUserEthernet 1.0.1
>usb.!UUserHCI 1
|IO!BSerialManager 8.0.5d7
@Dont_Steal_Mac_OS_X 7.0.0
>!AHV 1
>!ADiskImages2 1
>!A!IHD5000Graphics 16.0.5
>!AHDA 283.15
>!A!ISlowAdaptiveClocking 4.0.0
>eficheck 1
>!ASMCLMU 212
>!ACameraInterface 7.6.0
>!AThunderboltIP 4.0.3
>!ABacklight 180.3
>!ALPC 3.1
>!A!IFramebufferAzul 16.0.5
>!AMCCSControl 1.14
|SCSITaskUserClient 436.140.1
|IO!BUSBDFU 8.0.5d7
>!UTCKeyEventDriver 256
>!UTCButtons 256
>!UTCKeyboard 256
>!UCardReader 511.141.1
>!AFileSystemDriver 3.0.1
@filesystems.tmpfs 1
@filesystems.hfs.kext 556.100.12
@BootCache 40
@!AFSCompression.!AFSCompressionTypeZlib 1.0.0
@!AFSCompression.!AFSCompressionTypeDataless 1.0.0d1
@filesystems.apfs 1677.141.3
>!AAHCIPort 346.100.2
>AirPort.BrcmNIC 1400.1.1
@private.KextAudit 1.0
>!ASmartBatteryManager 161.0.0
>!ARTC 2.0
>!AACPIButtons 6.1
>!AHPET 1.8
>!ASMBIOS 2.1
>!AACPIEC 6.1
>!AAPIC 1.7
@!ASystemPolicy 2.0.0
@nke.applicationfirewall 311
|IOKitRegistryCompatibility 1
|EndpointSecurity 1
@kext.triggers 1.0
>!AGraphicsControl 6.3.6
|IOAVB!F 940.4
|IOEthernetAVB!C 1.1.0
>DspFuncLib 283.15
@kext.OSvKernDSPLib 529
@!AGPUWrangler 6.3.6
|IOSlowAdaptiveClocking!F 1.0.0
>X86PlatformPlugin 1.0.0
>!AHDA!C 283.15
|IOHDA!F 283.15
@plugin.IOgPTPPlugin 985.2
>!AThunderboltDPOutAdapter 8.1.4
>!ABacklightExpert 1.1.0
|IONDRVSupport 585.2
|IOAudio!F 300.6.1
@vecLib.kext 1.2.0
>driverkit.serial 6.0.0
|IOSerial!F 11
>IOPlatformPlugin!F 6.0.0d8
|IOAccelerator!F2 442.9
@!AGraphicsDeviceControl 6.3.6
|IOGraphics!F 585.2
>!ASMBus!C 1.0.18d1
|Broadcom!BHost!CUSBTransport 8.0.5d7
|IO!BHost!CUSBTransport 8.0.5d7
|IO!BHost!CTransport 8.0.5d7
>usb.!UHub 1.2
>!UMultitouch 264
>usb.IOUSBHostHIDDevice 1.2
>usb.cdc 5.0.0
>usb.networking 5.0.0
>usb.!UHostCompositeDevice 1.2
>!AThunderboltDPInAdapter 8.1.4
>!AThunderboltDPAdapter!F 8.1.4
>!AThunderboltPCIDownAdapter 4.1.1
>!ABSDKextStarter 3
|IOSurface 290.8.1
@filesystems.hfs.encodings.kext 1
>!AXsanScheme 3
|IOAHCIBlock!S 332
|IOAHCI!F 294.100.1
>!AThunderboltNHI 7.2.8
|IOThunderbolt!F 9.3.2
|IO80211!F 1200.12.2b1
|IOSkywalk!F 1
>mDNSOffloadUserClient 1.0.1b8
>corecapture 1.0.4
>!A!ILpssGspi 3.0.60
>usb.!UHostPacketFilter 1.0
|IOUSB!F 900.4.2
>usb.!UXHCIPCI 1.2
>usb.!UXHCI 1.2
>!AEFINVRAM 2.1
>!AEFIRuntime 2.1
|IOSMBus!F 1.1
|IOHID!F 2.0.0
$!AImage4 3.0.0
|IOTimeSync!F 985.2
|IONetworking!F 3.4
>DiskImages 493.0.0
|IO!B!F 8.0.5d7
|IOReport!F 47
|IO!BPacketLogger 8.0.5d7
$quarantine 4
$sandbox 300.0
@kext.!AMatch 1.0.0d1
|CoreAnalytics!F 1
>!ASSE 1.0
>!AKeyStore 2
>!UTDM 511.141.1
|IOUSBMass!SDriver 184.140.2
|IOSCSIBlockCommandsDevice 436.140.1
|IO!S!F 2.1
|IOSCSIArchitectureModel!F 436.140.1
>!AMobileFileIntegrity 1.0.5
@kext.CoreTrust 1
>!AFDEKeyStore 28.30
>!AEffaceable!S 1.0
>!ACredentialManager 1.0
>KernelRelayHost 1
|IOUSBHost!F 1.2
>!UHostMergeProperties 1.2
>usb.!UCommon 1.0
>!ABusPower!C 1.0
>!ASEPManager 1.0.1
>IOSlaveProcessor 1
>!AACPIPlatform 6.1
>!ASMC 3.1.9
|IOPCI!F 2.9
|IOACPI!F 1.4
>watchdog 1
@kec.pthread 1
@kec.corecrypto 11.1
@kec.Libm 1
Mac Crashing every hour or so using QLC+
Memory leak inside a QLC+ process -> what version do you use? Latest?tonymoore wrote: ↑Thu Oct 13, 2022 1:48 am panic(cpu 3 caller 0xffffff801f0a12ee): "No more room to grow table: 0x0xffffff8020075a00 size:262142, used:262141, requested elem:1"@/System/Volumes/Data/SWE/macOS/BuildRoots/37599d3d49/Library/Caches/com.apple.xbs/Sources/xnu/xnu-7195.141.39/osfmk/kern/ltable.c:494
- Real Name: Tony Moore
Please can you tell me where I find a build number - All the ABOUT screen says is 4.12.6
File attached
Thank you
File attached
Thank you
- AWAKE_MAIN BUILD.qxw
- (59.11 KiB) Downloaded 265 times
It just crashed again and I lost half an hours work !! - Is there anyway of instigating an Auto Save function, whilst this bug still occurs that would be a life saver - It's not always easy to remember to keep saving every change you make as you go along
Thank you
Thank you
ehhm ... your project makes QLC+ crash on opening. This means something is fishy...
Let's have a look -> clearing the interface from universe 1 let's me open your project.
Except that Hopium1 and Blue 2 share the same functionality (meaning inside a soloframe that they do cancel them bilateral), I can't see to find any problems.
I'm on PC - so this might not be a fair test.
- Real Name: Svart Adam Solander
Did you find a solution for this? I also have version 4.12.6 and my mac (MacBook Pro Mid 2015, Big Sur) keeps crashing. :/
I've included my project as well.
- I era själar.qxw
- (52.36 KiB) Downloaded 113 times
Svart,
Never use the mix of an universe for in & outputs.
I see in universe 1 you have Artnet in and DMX out ... this potential leads to internal buffer over runs.
You are not limited in any way to use QLC+ universes, so split in & output to its own universe.
- sbenejam
Solander, can you try QLC+ with a simple project and confirm that QLC+ stills crashing. Can you explain how you use this project?. Can you explain how you plays this project during the show. QLC+ crashes when you click on a certain button?. The crashes occurs when you are editing, scenes or functions?.
I'm testing your project on Ubuntu 22.04 and I don't have any issues when using the buttons to activate scenes.
sbenejam,
I didn't do any changes when it crashed. Just set intensity and color on 10 different fixtures, and let them be. After maybe 10-30 minutes the computer just displayed error screen and rebooted. I had about the same error dump as the author of the thread.
I've downgraded to version 4.12.3 and now I've no issues with crashing. The show is really simple so I will stick with this version for now.
When I have time, I will try it with a simpler project. We're in rehearsing now with premiere on Friday.
So your problem does nothing have to do with QLC+. It's your system (!)
QLC+ crashes quietly and disappears, but your system is still up and running. You can restart QLC+ afterward with no problems.
This is not the case with you, so something else plays along.
Wasn't 12.3 the version before multi-threading was introduced?
This could explain why your system keeps running. The cores of your processor aren't under stress now. I would start being skeptical about your hardware if you use it in productions...
Your project __is__ simple. Don't worry about this. You don't have EFX running, nor RGB panels, nor animations. These are the CPU intensive blocks of QLC+. I would have it run on a Raspberry Pi 3.
- Real Name: Conny J
I had the same problem this weekend, got the same error and reboot.
I had everything in one universe, midi in and dmx out. Qlc was taking like 80% of the cpu.
I have now separate it, and qlc wont take more than 30% for now, i tested it yesterday and didnt reboot.
Also it did reboot when i was programming the midi, only playback seems ok for now.
