Problem changing Scene names
Sophia1
Real Name: Sophia
Hi everyone,
I'm using QLC+ 4.12.6 on Windows 11 Pro (system info is attached).
I'm trying to clone scenes and change it's name, but on some of the scenes, it doesn't "let me".
I'm changing the name of the scene, but it doesn't reflect under the scene list :|
I'm attaching a screenshot+system info+the QXW.
Thank you so much!!
Sophia
Bank1.qxw
(48.31 KiB) Downloaded 112 times
Sophia1
Real Name: Sophia
System info attached:
Microsoft Windows [Version 10.0.22621.521]
(c) Microsoft Corporation. All rights reserved.
C:\Users\Lenovo1>systeminfo
Host Name: SUPERPC1
OS Name: Microsoft Windows 11 Pro
OS Version: 10.0.22621 N/A Build 22621
OS Manufacturer: Microsoft Corporation
OS Configuration: Standalone Workstation
OS Build Type: Multiprocessor Free
Registered Owner: Lenovo1
Registered Organization:
Product ID:
Original Install Date: 10/5/2022, 3:32:29 PM
System Boot Time: 10/7/2022, 12:45:36 PM
System Manufacturer: LENOVO
System Model: 82HU
System Type: x64-based PC
Processor(s): 1 Processor(s) Installed.
[01]: AMD64 Family 23 Model 104 Stepping 1 AuthenticAMD ~1801 Mhz
BIOS Version: LENOVO GJCN27WW, 5/5/2022
Windows Directory: C:\WINDOWS
System Directory: C:\WINDOWS\system32
Boot Device: \Device\HarddiskVolume1
System Locale: he;Hebrew
Input Locale: en-us;English (United States)
Time Zone: (UTC-08:00) Pacific Time (US & Canada)
Total Physical Memory: 15,718 MB
Available Physical Memory: 7,662 MB
Virtual Memory: Max Size: 21,862 MB
Virtual Memory: Available: 11,167 MB
Virtual Memory: In Use: 10,695 MB
Page File Location(s): C:\pagefile.sys
Domain: WORKGROUP
Logon Server: \\SUPERPC1
Hotfix(s): 3 Hotfix(s) Installed.
[01]: KB5017271
[02]: KB5017321
[03]: KB5017233
Network Card(s): 6 NIC(s) Installed.
[01]: ExpressVPN TUN Driver
Connection Name: Local Area Connection
DHCP Enabled: No
IP address(es)
[01]: 10.97.0.6
[02]: ExpressVPN TAP Adapter
Connection Name: Ethernet
Status: Media disconnected
[03]: VirtualBox Host-Only Ethernet Adapter
Connection Name: VirtualBox Host-Only Network
DHCP Enabled: No
IP address(es)
[01]: 192.168.56.1
[04]: Wintun Userspace Tunnel
Connection Name: OpenVPN Wintun
[05]: TAP-Windows Adapter V9
Connection Name: Local Area Connection 2
[06]: Killer(R) Wi-Fi 6E AX1675x 160MHz Wireless Network Adapter (210NGW)
Connection Name: Wi-Fi
DHCP Enabled: Yes
DHCP Server: 10.30.50.254
IP address(es)
[01]: 10.30.50.31
Hyper-V Requirements: VM Monitor Mode Extensions: Yes
Virtualization Enabled In Firmware: Yes
Second Level Address Translation: Yes
Data Execution Prevention Available: Yes
C:\Users\Lenovo1>
How do you leave the name field? By [enter] or [tab]?
Sophia1
Real Name: Sophia
Yup, I have... I also tried to save and close the app and reopen it multiple time... doesn't help 😬
I tried your project and I have no problems changing the labels or names...
Do you let QLC+ run under administrator rights? <- just an idee...
Sophia1
Real Name: Sophia
Yup, tried on "run as admin", no improvement :|
It seems like the problem is specifically when cloning "AMBER" for some reason...
I think I'll leave it as this. I'm not THAT motivated to fix it 😅
I can live with this bug. Thanks anyhow!!
kenact
Real Name: Ken Coughlin
The project you uploaded does not appear to be the same project you took screen shots of. Your screen shot shows an AMBER (Copy), in the folder ALL 20% LED Lights. In the project you uploaded, there is no such scene.
LightJr
Real Name: Alberto
Same problem.
Also when I try to move any Collection inside a folder, save the project, close QLC+ and reopen the project, the collections aren't in the same folder but appear in the root folder. If I create a new folder, move the collection inside it, save, close and reopen then it works.
Yestalgia
Windows 11 seems to be causing a few problems. Can you go back to windows 10?
LightJr
Real Name: Alberto
Yestalgia wrote: Sun Jun 04, 2023 2:30 am Windows 11 seems to be causing a few problems. Can you go back to windows 10?
I have Win 10
Ed Windows 10 Pro
Ver 21H2
Build 19044.2965
