does anybody know whether this encoder Board can be usen in QLC+ for example x y z Axis controller for a movinglight?
thanks
DJ Techtools Midi Fighter Twister
Depending on what midi mode it uses ? Yes?
x y z isn't what you are looking for in conjunction with moving heads... It's 2D pan and tilt (the 3th dimension you get for free)
- Real Name: dominik
hello there
unfortunatelly testing was no success.
the encoder wheel(s )show strange behaivour like on the fist turn of the knob value increases from 0 to 127 or 130 and remain there . i cannot lower the value, it hangs around127 and 130
any thoughts ?
any thoughts ?
what i noticed is that DJ Techtools Midi Fighter Twister encoder sends a midi command which increases from 0 to 130 no matter what direction of turn i use
this means clockwise or anti clockwise generates the same command
strange isnt it?
strange isnt it?
and what is even more strange ... midi is 7bit so there is NO digital possibility to get a value of 130...
How or where do you read these values? I think, for debugging purposes, it's better to use a midi tool.
It also might be that your device is sending CC signals, which are mal-interpreted.
If the VC is showing you 130 (or 131 - depending on the flip-side-of-things) You got Input - and that is important.
How things will come out, that's the manual to say...
