Hi Forum,
I am a longtime usere of QLC+. I recently renewed my computer, now I am using a Microsoft Surface Pro with a high resolution display (2736 x 1824).
I have checked this link: https://www.qlcplus.org/docs/html_en_EN ... swers.html
But somehow it seems I can not get it working.
I have added this to the QLC+ shortcut: C:\QLC+\qlcplus.exe SET QT_AUTO_SCREEN_SCALE_FACTOR=1
My old QLC+ desk is still shown very slow on my new computer, as pixels are mapped 1:1.
Can someone help me and explain the steps from link above? Maybe I did something wrong.
Best regards!
QLC+ with high DPI screens
This one is wrong. You have to set an environmental variable.
Verify with [windows]+[R] cmd + [enter]
Now you get a dos box. Enter the command SET + [enter]
All environmental variables will be listed.
For the Qt libraries to work correctly, it needs this variable: QT_AUTO_SCREEN_SCALE_FACTOR=1
manually enter "SET QT_AUTO_SCREEN_SCALE_FACTOR=1"
and start QLC+.
Now, this should work.
The document you are referring to does the same, but not manually: C:\Windows\System32\cmd.exe /c "SET QT_AUTO_SCREEN_SCALE_FACTOR=1 && START /D ^"C:\QLC+^" qlcplus.exe"
Thank you, GGGss! But unfortunately also your well described method does not change the look of QLC+ on my machine.
Runnning the command "SET QT_AUTO_SCREEN_SCALE_FACTOR=1" in the command windows is accepted, meaning there is no error message.
