Can QLC+ output sACN?
If not and I have to use Artnet, how do you set up the port? Checked everything I could in Inputs/Outputs section, but no port configuration…trying to communicate with a CueSevrver2. CueServer2 can accept Artnet, but needs to know port config/address.
Anyone have any advise?
sACN and Artnet
It's called E1.31
Here are the full docs: https://www.qlcplus.org/docs/html_en_EN/e131plugin.html
I think in the main tab you select source network device, and in the setting you either select multicast or enter IP of your target device
