MIDI-Input function / problems
julianb240393
Real Name: Julian
Hi Guys,
I am trying to trigger some Buttons in the Virtual Console with a MIDI-Device. I want to build a Footswitch with an Arduino and get the MIDI-Signals through "hairless-midi-bridge" and "LoopMIDI" into QLC+.
So for this I have a button on an digital-input of the arduino. That works. In the Monitor of hairless-midi-bridge there is "Note-On" and "Note-Off" or "Note-On Vel.127" and "Note-On Vel.0" for Midi Channel 1, Note C-2.
But if I configure the Midi-Input in QLC and "Auto-Detect" it to my button, if I hit the switch, it only works in 8 out of 10 times, that the button in QLC really activates or deactivates.
Each time I hit the switch, the button in QLC "blinks" but most times, nothing happens. You gotta have luck, that the button activates.
What could this be ? Anyone had this problem before ?
julianb240393
Real Name: Julian
Anyone who knows what the problem could be ?
I can make a video if that helps.
I'd start to log all midi commands into a .txt file. I think there are debugging tools for that.
This is the only way to monitor midi signals.
Now to your 'fault': it might be that your switch has to be debounced. Is there a possibility that when you press the switch it actually makes / breaks signals 2 or 3 times? This would lead to multiple double midi commands - ergo QLC+ buttons blinking but not doing anything.
Did you create an input-profile for your setup? Did you apply the 'simulate 2nd press' to some channels?
julianb240393
Real Name: Julian
GGGss wrote: Wed Sep 07, 2022 6:22 am Now to your 'fault': it might be that your switch has to be debounced. Is there a possibility that when you press the switch it actually makes / breaks signals 2 or 3 times? This would lead to multiple double midi commands - ergo QLC+ buttons blinking but not doing anything.
The program of the arduino does only output 1 single note, when I press the switch. In the MIDI-bridge I can see this, but I will try to log the MIDI-Data to see that exactly.
I also created a Input-Profile and tried all the options, but nothing worked
