Say you have a basic setup - see the project file annexed
Operate mode
select 'base light intensity'
select 'base position'
Switching on EFX Q3-EFXR0x? width variable
plays an EFX.
Important: EFX Width here is 10
The EFX width slider is in level mode and set to U LB and channel 1
The width property of the XY-pad on VC is set to U4 Ch1 ^^ the slider
Manipulate or whatever you do; you cannot change the width property of the XY-pad <- bad
TuubTuub : [here] https://youtu.be/2iwcphSWvI4
EFX2 .. CTE - issue 3: widget XY-pad + Loopback control not
- DBp3Q1-fade-on-EFX.qxw
- (12.34 KiB) Downloaded 34 times
