One Fixture Scene: Copy to another fixture
DSTN
Hey, I would like to setup my scenes singely for every fixture and then combine the scenes via collections.
Very often I want to get from...
Scenes
| - par0-color-red
to
Scenes
| - par0-color-red
| - par1-color-red
... is there a fast way to do so (i. e. copy many many scenes from one fixture to another fixture)?
(by now I change the fixture id in the savefile via text editor)
Regards!
There is no 'multi-copy' possibility unless you go and tweak the project file thru a text editor. (note: create a backup first... is you break the structure of the file; you break your project)
I'm doubting that using collections only to combine some scenes to some fixtures is the best workflow.
You might use the dump DMX feature. (You choose the look you like and dump all actual values into 1 scene)
