Hey, i recently put myself back into QLC + but i just ran into a situation that i don't know how to solve.
I was in the VC and i accidently push the " ' " and the " ^ " buttons of my keyboard. At this moment it created a sort of auto select of my buttons and i can't take the control back. When i'm into this "shuffle" mode the others buttons are put in grey and therefore not actionable. I don't know how to get out of this mode and even restarting QLC doesn't work.
I really don't know how to fix that, send help !
thx
i added a screenshot of a test i did to undestand how it works but i'm still without any answer.
Troubles with Grey Buttons in the VC
- edogawa
- Real Name: Edgar Aichinger
It looks as if the frame widget got deactivated...
Try to go to the frame's properties dialog and tick the checkboxes to show titlebar and activation button; if it shows a pale green arrow on white background, the frame got disabled somehow (although here under Linux, if I disable and then hide the titlebar and activation button again, its area isn't removed from the widget size).
Interestingly, the keystrokes you mention do nothing here.
EDIT: found a small bug while trying this: when repeatedly showing and hiding the title and activation button in deactivated state, the "left over" area above the original widget where the title used to be gets ignored and a new title added on top of that, so with time the widget gets taller and taller.
